Gurley's 92 Teal 2JZ Project
te72
Classifieds Moderator
6,618
9
WHYoming
Crypton2006;1783314 said:
Really I thought poop was the main topic when we where 5. Not 25....lol
Hey, I'm 28... and a half. :p
gurley0916;1783370 said:
Car is getting fuel done to it right now and hope to have it running by the first of the year with e85 and proefi
So... is your car gonna smell like corn when you're running the E85 Dustin? Because if so, someone needs to figure out how to power a car with potatoes...
stevenr816
932
Phoenix,AZ
IBoughtASupra;1783868 said:
I hear E-85 and Meth smells like bubblegum. Not sure if it is true though.
:dunno:
Hhaha no lol, go grab an e85 nozzle and smell it. It smells better then gasoline IMO
Now q16 on the other hand is sex and smells amazing. I use to put it on a piece of paper and let it dry so I could sniff it lol
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
The smell of e85 burnt smells nothing like at the pump...i hate the smell when it burns
Sent from my SCH-I500 using Tapatalk
gurley0916
Mar 10, 2008
1,138
Columbus,OH
Been a while but I have been stripping my manifolds and getting ready to send them out for polish, my valve covers being sent out for wrinkle black powder coat and getting tapped for -6an fittings for a future PVC system revamp. I bought my black stainless steel teflon lines for my fuel. Im going to run a -10 feed to the motor and split it to two -8 lines to the rail. From there a -6 return. So I got 15ft of -10 and -6 and 8ft of -8 line. Also got my fuel injector clinics top feed -10 fuel rail and Injector Dynamics 1000cc injectors. Also here is a pic of the car as it sits...why yes those are Brian Crower 264's sitting in there how did you know!!
all that is left is to get the fuel pump (SX performace), get the regulator, and the fittings for the fuel line. I need to get the ethanol content analyzer and ethanol sensor and adjustable cam gears and the car will be ready to get tuned. Just picked up some sway bars that will be going on as well. So close but so far...
Albert
May 13, 2009
1,710
Tempe, AZ
Your valve covers are almost done, I'm going to drill out the baffles and add tapped harware like the 1jz covers, if you don't mind? KK? Good shut up
xzeror
1,356
Miramar, FL
hey gurley, i just wanted to know what you went through to clean up the engine bay so well. Where did everything go? Im dropping my 2jz soon and im going to paint and try to clean my bay up a bit as well. Thanks.
IBoughtASupra
4,455
Queens, NY
You don't want crap and dust and what not in the baffling. You know, the 1JZ is smart, we have screws there, the 2JZ doesn't, you know, since it was the dumber of the two. :D
Albert
May 13, 2009
1,710
Tempe, AZ
Yeah, sand blasting material behind it, chips from when I drill tap for PCV, foreign objects like Andy....
It's okay I won't pull a Steven and try tapping it with a left hand tap.....
Albert
May 13, 2009
1,710
Tempe, AZ
gurley0916;1786723 said:
Whatever gets you to sleep at night...funny how u never hear. "1jz No Shit!"
I hear that every time people see my engine bay..... Followed by "why not a 2jz brah?"
IBoughtASupra
4,455
Queens, NY
While you are there, why just just weld the fitting on? Press fit the weld on the inside.
Less foreign objects....:D
"Why not 2JZ Brah?" Would you rather be first or second?
