Group A's group a rebuild
LOL Yannis!
I use the Moroso race Filters once the motors broken in and I start revving it as they're a heavy wall can so less chance of splitting a seam. (and they're plain white so no bling)
Yannis: Steve is talking 100+ PSI so I'd be hesitant using a crimped filter at that sort of pressure and being VERY careful to keep the motor under 2000 rpm till the Oil was warm and thinner! ;)
I had a stuck relief valve in a BBC Oil pump way back and it pumped all 15 litres onto the floor in 20 seconds!
yannis-supras
Lag hater
Jun 13, 2005
331
Athens, Greece
:icon_conf :icon_frow bummer!!! What about 60-70psi pressure? Would it still be that bad? I guess that's higher than average for the 7m still, right?
And speaking of oil pressure (right from your thread Ian :naughty:) would a 5-6mm washer be sufficient for shimming my pump for that kind of pressure?
group a supra said:
ian i was thinking of the canton filter to match ;)
There's the dick size thing Steve ;)
Yannis: 70 is fine on any filter!
(same warning when it's cold though)
It all depends on tolerances in the Motor Yannis there's no hard fast rule to xxmm=xxpsi.
group a supra
SPAWNING AN INTERCEPTOR
ok new parts woot woot
lipp fuel rail
-10 x 2 inlets :)
pwr rad
110lph water pump and controller
