Grinding Transmission
LoveMy7MGTE
162
Grosse Pointe, Michigan
Not sure if any1 has had this prob, but ocassionaly my tranny grinds when shifting to reverse. Dont know whats up with this cuz it doesnt happen in any other gear, I press the clutch all the way in, and it grinds like the clutch is still engaged. Any ideas?
gixxer750
2jzget comingsoon!
Mississippi
I always go first, then reverse... Works like a charm. My new trans however doesn't have this problem, but I still go first then reverse, as it could prevent the reverse grind problem in the future.
LoveMy7MGTE
162
i should have mentioned that it doesnt do this if i go from 3rd to reverse, any other gear, or neutral, still grinds.
LoveMy: Reverse is a straight cut Dog gear so you're actually shifting a gear not a synchro when you engage it.... Sometimes you can slip it in at just the right time others it will grind/crunch.
I find with my new Tremec if I nudge it towards 5th first it's fine as this stops any clutch drag from spinning the input shaft while you have the pedal down letting reverse engage while stopped.
(Not many of you guys would be old enough to have driven a "Crash Box" non synchro trans)
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Oh shoosh old man. I drove an old Sprite or was it a TVR I dunno... double clutch the thing and rev match the whole time got real old.
But back to the grinding... yes you need to shift into another gear before reverse.
shaeff
Kurt is FTMFW x2!!!!
11
Around
does my '71 chevy c-10, 3 speed manual count? ;)
-shaeff
Jon: LOL you young kids and your racing cars in my day we.........
where was I? who are you people...... MATLOCKKKKKKKKKKKKKK. ;)
Shaeff: I'm guessing it still has synchros !
boost fiend
852
Rockford, Il
'71 chalenger. '73 duster. and soon to be in my greasy mits a '55 packard(44k ORIGINAL miles. 1 owner((girlfriends grandpa)) ). lets not talk about "young kids shifting non syncro trannys".:evil2:
