Gran Turismo 5: Supra 3.0 Turbo A Drift Setup
MA70witBoost
Registered Drifter
Has anyone been able to successfuly setup their Supra to oversteer in the game? Im having trouble getting the car to turn and dont like slowing down as an option. Also getting really annoyed with the snap oversteer. Feels like Im driving a AWD and always have to steer into the turn as opposed to counter steering. What setup are you guys currently running? Whats your suspension tune?
iwannadie
981
gilbert, az
Not to ask the obvious but you've turned off all the assists right? I have no problem sliding my mk3.
I drove a rally race with a default car and forgot to turn off all the assists and it was like trying an AWD glued to the road. Turned off the assists and I was sliding around every turn with that car.
87mk111
Metal Head
Sep 29, 2009
481
akron/canton, ohio
weird that youre having problems with the SUpra sliding, i could get a Miata with just the level one coilovers to slide decently. BUt in gran turismo 4, i always had problems with the mk3 understeering.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
MA70witBoost;1656335 said:
Anything yet?
ops i for got let me fire it up
give it a abit and you will master it
sport hard tires front rear you choose on how much traction you want
max out everything to buy but trans not need
ride hight -25/-25
spring rate 14.3/6.8
dampers ex 5/3
dampers comp 5/3
roll bar 1/2
aligment
camber 0.5/1.5
toe 00.5/-0.10
brakes 6/7 or other way aroud you choose
lsd
torque 20
sensistivity 40
braking 30
have fun
oh yae every assit truned off abs set to 1
te72
Classifieds Moderator
6,626
10
WHYoming
I use my JZA70 for a lot of things. It's set up quite similarly to my actual car, really... Never had a problem getting either sideways. Hell, turn in, throttle down, boost comes on, counter steer and modulate throttle. Easy as that to *get* it sideways, but getting it out smoothly is the challenge for me.
MA70witBoost
Registered Drifter
ride hight -25/-25
dampers ex 5/3
dampers comp 5/3
roll bar 1/2
aligment
camber 0.5/1.5
toe 00.5/-0.10
lsd
torque 20
sensistivity 40
braking 30
have fun
Going to give this a try. Need I mention that my Turbo A has EVERY performance mod available and is at 564hp @ 6900RPM if i see correctly. NashMan, what kind of tires are you running?
EDIT: Just did a run with your setup NashMan and I still need the hand brake. Im currently running Racing Soft all around and am going to mess around with different tire combinations and see what i get.
EDIT: Ok, car oversteers a bit too much with Racing Soft up front and Racing Hards in the back. Gonna try Racing Mediums in the back and see how the combo works out.
Kangae
Buzzin' Half Dozen
Sep 13, 2007
249
Utica, New York
Well you really shouldn't be having a problem. You arnt just full throttling from a straight right into the turn are you? That'll give you "understeer" no matter what car you're using. The key is to transfer weight, an easy way to do that is to use the normal brake only slightly to shift the weight to the front, or you can fake to the outside and cut inside to force a drift.
Sent from my Droid using Tapatalk
MA70witBoost
Registered Drifter
well yeah, thats kinda what im doing. im trying to minimize braking time and give it gas till the last moment, braking hard and taking the turn but properly timing when to start braking is difficult.
Kangae
Buzzin' Half Dozen
Sep 13, 2007
249
Utica, New York
Yeah, it usually takes some practice to get it down. My problem is that I always end up going faster than I think I am, but that was usually on forza.
But I think I can see where you're coming from, my only suggestion if you haven't done this already would be to work your way up to a fully tuned mk3. I know it took me awhile to get any sort of drifting down, and even now I can blow it from time to time.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
i use sport hards on all corners
MA70witBoost
Registered Drifter
Im the same way. Racing Sim's are no where close to the real thing. The lack of G Force affects the realism IMO. That and I dont exactly find GT5's vehicle dynamics or the accel of the motor to be 100% realistic. Damn cars sometimes die on powe and wont accelerate after initiating a loss of traction till the tires finally grip again.
Hmmm... Going to try this.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
i have no issue and with this set up does not snap over streer as easy
if you don't wana use the e brake as much put more rear brake and lessen the front
i have it this way for mid drift slow down and change angle
i still use my e brake when tire damge is off the car made for online play
Supra0089
367
New Hampshire
Yup, you have to slow down to corner...no matter what the setup...easiest remedy is put front brakes to 7 and rears to 3 and taht will get the rear around for ya
te72
6,626
10
WHYoming
I see your logic here, but this will generally cause understeer. Front wheels lock up when they have more brake bias, whereas the rear tires will lock up (and initiate a slide) if you have more rear bias. ;)
MA70witBoost
Registered Drifter
Whao, you just changed how i thought. I thought that more brake bias towards the front would help remove the weight off the back tires through cornering alowing the back to break lose easier because the weight of the vehicle was removed from the rear making it easier to oversteer. Initially a braking drift. Im thinking about the vehicle dynamics in my head and I thought that slightly planting the front would increase overall front traction and help with turning.
