Finally got rid of 51. I adjusted the TPS old school method.
Closed throttle my SAFCII is reading 0.560V. If i move even to .565 i will get 51 again. Problem is when i hit full throttle its only to to 3.6XX volts. So one, the safc isn't reading 100% throttle and two, how does the ECU respond to this? will it learn its at 100% or must it see the standard 4.0+volts
could this be cause maybe b/c my throttle plate is out of adjustment?
edit: FYI TPS has 6K miles on it.
