Got a free Celica today, what to do with it?
89Turbo
804
Portland
so i got a free 89 Yota Celica ST(BASE model) with a thrown rod, sounds HORRIBLE but still will move under its own power. Perfect interior, perfect body, and all accesories(ps, ac, stereo) work, and its also 5spd. Sooo im obviously going to need to pull the motor and put a new bottom end in it. Worth it? or not? i have the Supra as a daily driver now but would much rather have this as a DD so i can do some extensive projects on the supra without worrying about it. Also has plates from a different state and tags that expired in 05(more $$) Fix it, or send it to the scrap yard before i put it in my name?
JoeC
338
Vancouver, Washington
22RE's have been built reliable many times. Far more reliable than the 7m will be from what I've heard. But you can also stick a 7m in there. Otherwise.. Let us have some interior parts and then scrap it for $150.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Put an altezza beams engine in it 4th gen 3sge 220 hp stock or a 245hp 3rd gen mr2 3sgte engine in it!
i knew some one that put the 3rd gen 3sgte into a 1996 camry 2 door manuel setup was fast!
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
What color is it? You wanna give me both headlights assemblies and the front passenger qp and the drivers side door lock guard thing if you decide to scrap it? lol
JMDigital
Authorized Vendor
Jun 2, 2006
976
Tampa, Florida
If your supra is the project. Then I think the best advise is dont make this another go-fast project. You said this could be your daily driver right? So make it one. Fix it, make it fairly reliable and keep it stock. Spend as little as you can on it and drive it. Put the big bucks in the SUPRA. I know it could be another swap project like others have said, but you said
"i have the Supra as a daily driver now but would much rather have this as a DD so i can do some extensive projects on the supra without worrying about it."
So do that.
