kotu100;1333064 said:nice thats about what i spent on mine. cheap azz builds FTMFW!
Did you get new pistons too?
rayall01;1333126 said:Did you get new pistons too?
kotu100;1333554 said:yuppistons, rings, bearings, water pump, timing belt, and head and block machined, and MHG for just over $550
rayall01;1333922 said:Cool! I had to use a bunch of stuff from my stepson's abortion. I got his HKS stopper, and undercut ARP studs, as well as his new water pump, and oil pump. I got a good package deal on the pistons, rings, bearings, and wrist pins, and a fair deal on a gasket set. I needed a new thermostat housing, which added another 25.00 to it. Plus I spent a fair amount on sandpaper for decking the block and head. Hey, it all worked out in the end.
kotu100;1334069 said:thats all that matters. when u bringin that beast to the dragway? me and a bunch of my buddys are goin on friday next week. would be nice to not be the only mkiii reppin.
LilMissMkIII;1335748 said:Wow, just thread through your thread... Nice work!
IJ.;1339913 said:No more than 36ft/lbs when you install it![]()
IJ.;1340154 said:I wouldn't risk it even at 36 I measured half a thou bore deformation on a late style heavy wall block.... up to you dude.
arizzle;1340687 said:looking good, looking at it makes me want to fix my supra already.
rayall01;1340620 said:I was playing! 30 ft lbs tops.
IJ.;1340708 said:Gotya problem being the young guys read it don't realise you were joking and pull the tensioner bolt to 50ft/lbs (easy to do as it's a big diameter fine pitch bolt) and end up pulling #1 bore and then can't understand why their dip stick keeps popping out under boost![]()
rayall01;1340842 said:Those f-ing young guys are a pain in the ass, eh?
