if anyone can help me out, what bell housing do i need to swap the type 233 transmition, cause i got a used 6spd, but i dont know if itll strait bolt up to my 1j or not
Well, if you have a 233 (V160), you should notice that the bellhousing is actually part of the transmission, and not replaceable.bloodasp90 said:if anyone can help me out, what bell housing do i need to swap the type 233 transmition, cause i got a used 6spd, but i dont know if itll strait bolt up to my 1j or not
annoyingrob said:Well, if you have a 233 (V160), you should notice that the bellhousing is actually part of the transmission, and not replaceable.
Fortunately the bolt pattern will bolt right up to a 1JZ no problem
Talk to Jawsgear about getting a 3.54 ring and pinion for your rear-end so you can actually use it too.
bloodasp90 said:well thats why i was asking cause i did notice the hole bellhousing thing with it, and whats the difference in the feel with a 3.54 rear with the 6spd
Andre said:The Mk4 came with an 3.2 diff
The Mk3 with an 3.73 are maybe you have an 3.9
I am running also the getrag in my mk3 with an 3.73 and he fisrt gear is very short so thats why you have to go as low as possible
3.54 is an option butt i heard jawss gear do not sell them anymore
Butt i drive the getrag with an 3.73 and the 1 gear is good foor spinning the wheels :icon_razz doing crazy things with the car
bloodasp90 said:so what you just start out in second or something? cause if i have to start in second then theres no point in even having a 6spd, cause ill never use all 6gears..
I would think closer gear spacing is another BIG benifit of the trans as well.OneJoeZee said:That's the real benefit of the Getrag.
I agree to an extent but that depends on the type of driving it's being used for. If it's mostly freeway stuff, it won't really make a difference as the top 3 gears are pretty much the same on both. Light to light or other lower speed situations would definately be different. Not sure if good or bad though. Probably depends on the power you make, what tire you have, and the diff. I only have limited experience driving a V160. I'm just talking from looking at t the ratios. Maybe Sean(2JZMK3) will chime in about using both.tissimo said:I would think closer gear spacing is another BIG benifit of the trans as well.
annoyingrob said:Really? From where?
DonS1mpson said:It doesn't matter how much you got the transmission for, just because it is cheap doesn't mean it's a good idea.
You're looking at doing a lot of custom work to get the transmission in the car and working with the MKIV diff, so much work that you're going to have to spend that initial outlay of $155 many times over.
To be honest mate, you sound like a guy that only wants the Getrag because it has 6 gears - That's the WRONG reason to get one installed in your car.
The reason to go through all the time, hassle and expense related in sticking the Getrag in your car is if you're shooting for some BIG numbers and if you were, it's likely you wouldn't give a rats ass about not being able to use all 6 gears.
