general questions about my 86.5, what to do and how to do it.
ValgeKotkas
2,224
Over the pond
Already investigated it like half a year ago :) Though haven't bothered actually doing the process, as some people say it's really pointless.
Who cares about the air there?? One guy once asked whether I have some rocket-system or something in my car :D
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Because it could escape and get into other parts of the cooling system and cause a heat pocket?
And if after you bleed it, the problem comes back, you know you have something to worry about. It's like you're ignoring a diagnosis tool imo.
Justin
Speakers?
Spokane, Wa
mk3 for life!;1018372 said:
that is a weep hole on the front timing cover. seems like one of your seals needs to be replaced if in fact it leaks out that hole. it is either the front main seal or the oil pump driveshaft seal. replacing them involves removing the head so this may not be a job you want to tackle on your own being it's your first Soup
Why do you say this? I really don't think you have to take the head off. Can you prove that you do?
Chris Brown:
If you're asking what the button that looks after market is that has been put in the steering column shroud, its for that after market alarm that has been installed. (poorly installed from the look of it)
If that's not what you were asking 'bout, disregard :)
Im Chris Brown
76
Palm Springs, CA
yea thats what i was asking about.
took it to the shop so we could figure out why my dash isnt lighting up. didnt have enough time to get to it but as we pulled out another tech noticed oil drops on the floor :(
prognosis?
mk3 for life!
Project Soupracharged
when my dad was helping me build mine and he installed the oil pump driveshaft seal the lip got ripped and it leaked oil out that weep hole.
the hole is there so that when you do get a leak it seeps out and does not fill the timing belt area with oil.
you do have to remove the head because it overlaps the rear timing cover which is where the seals are.
my dad tried that too and all he managed to do is fold the part of the head gasket that overlaps and tore it all to hell
TOP SIDE
BOTTOM SIDE
Im Chris Brown
76
Palm Springs, CA
mannnnnn.
i've got a feeling this isnt good
i got home, came inside then decided to go check for oil again. 30-45 mins passed i guess.
i got under and this is what i saw
it looks like the oil is not coming out of the weep hole, rather,
dripping down from wherever, running along the metal till it hits the weep hole, with the weep hole being the lowest point on the block (?) it then sits there till it gets too heavy and falls to the ground. That part is oily but unfortuantly it didnt show up in the picture
sooo.
good news is that i burrrlly passed smog today!
Justin
Speakers?
Spokane, Wa
Check these photos out.
Why would you have to take the head off when the seals are easily accessible by just removing the lower timing belt cover?
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
First things first use the Napa block tester and get that out of the way. If no BHG then you can proceed to fix other minor issues.
Have you done it yet? we're waiting......
If no BHG you may proceed...
I recommend you focus on safety issues first, brakes, glass, lights, gauges. Then move to maintenance items, belts, fluids, hoses, etc. Then finally worry about your cosmetic issues. No sence in having a perfect looking Supra that is unsafe or unsound to drive.
That oil could be dripping down from the distributor, that is a common leak and an easy fix. Try to find the source by tracing it back up the block. If you need to you may have to do some cleaning so you can see the fresh drippage. A minor oil leak is more of a pain than anything so long as you keep a good eye on your level. Compared to gasoline oil is cheap and you can afford to leak a few drops so dont panic. That being said however it is preferable to find and fix the leak.
As for your mouldings, I dont know of any way to repair the early model version. You will probably have to find replacements if you want them all looking right. Try the for sale section here, alot of guys "upgrade" to the later model mouldings and have the old set for sale.
For the door panels, you can actually just move over the leather insert part of the panel if you prefer. The leather inserts have a tendency to yellow and in my opinion look older than the cloth ones when worn.
It looks like you have a nice clean example of a first year mk3. Welcome to Supramania, the best mk3 site period!
mk3 for life!
lol i guess my memory is not as good as i thought it was.
i just called my dad and he reminded me that the reason we took the rear timing plate out was cause it was cracked and we did the seals while we were at it
i had it pictured in my head that the seal stop was in front not behind it
shouldve known better:nono:
Im Chris Brown
76
Palm Springs, CA
i havent got around to the NAPA test yet since its been only a day and i dont have the tools necessary to do it. Im a bit dishearted because we just had the intake removed and all the spark plugs out to change them, it would have been ideal to handle that at that time...butt..i guess thats how it goes.
I parked it at my friends house and got under to see where exactly it was dripping from. its not near the weep hole as i suspected but it was falling from the oil pan (i think?) i dont know if that changes anything or not..
They started troubleshooting why my dash went out today. The switch for my lights/turn signal is broken so we'll be replacing that as well. As soon as i figure out what that flowing liquid noise is and fix it, then replace the timing belt, the engine should be in perfect health. As is, all my friends say it sounds great and runs great, but i get an idea of how decieving that could be.
and i heavily agree on supramania being the best mkiii site ever. I defiantly like how it is focused on the mkiii rather than the mk4. The members are all really helpful. Its down.
:D
Im Chris Brown
76
Palm Springs, CA
took it into the shop due to oil leakage. they have no reason to believe its a BHG and i dont think they got to the NAPA test.
I found a nice 87 NA on craigslist for 2600 obo. has a fresh jdm 7m-ge with 55k on it and a bunch of other new stuff. If i can talk to this guy and see if he still has it or if it looks like its gonna go out the door quick or what, i think im going to try and sell the 86.5, break even/take a small hit and pick up the 87.
for timing belt, cam seals, (they think its leaking from there) and some other stuff it's gonna be 481. I need new hatch shocks, im missing the plastic piece that goes under the steering wheel, AC still doesnt work, interior's decently dirty. Theres just stuff, and too much of it that i really want to deal with...specially if timing will work out with me being able to pick up an 87 with 55k on the motor
Clueless
980
Columbus, Indiana
just get the motor rebuilt
Im Chris Brown
76
Palm Springs, CA
too much money
mad monies.
not that i cant essentially afford it, but it would make me really super poor. that, and, if i can get away with selling it and picking up this 87 NA that seems to be in better condition, why, that sounds all the more smarter.
Clueless
980
Columbus, Indiana
Im Chris Brown;1022118 said:
too much money
mad monies.
eventually that motor will need to be rebuilt too(unless it's been rebuilt recently)...besides, they say mk3 owners are poor people so you might as well get used to that feeling if you plan to keep an mk3.
Im Chris Brown
76
Palm Springs, CA
i dont think its been rebuilt recently...unless its really hiding stuff from us.
its running strong as is.
as stated, i think im going to try and sell it and pick up
87
actually, if i keep the 86.5 (borracho!) i was planning on swapping the motor/tranny in a year.5 or so, after i got my savings back up there. just need a reliable dd for a snag now
Im Chris Brown
76
Palm Springs, CA
school finished. i started the engine and the birdcage came on. i was like 'are you kidding me!?1' and let the car warm up. i started driving home, got some distance, stalled at a light and the birdcage went off. it came back on at some time and i had a rough shift and it went off again and stayed off till i got home
whats the deal? is a wire loose or am i faskeezed?
Clueless
980
Columbus, Indiana
welcome to supra-hood
