gas tank drain plug?
Mynes_3
135
cencal
was looking for it but cant find it. search already but nothing. have half tank of 91 so wanting to use it since the supra is dead. lol.. also do i have to drop the tank or no?
also, forgot to mention. about the greddy type s bov, i was reading about how people mod it into single spring. is there any reason to be running that or i mean pros and cons about it?
S.A. supra
2,405
Buda, Texas
is on the bottom of the fuel tank no need to pull off the tank. I use a socket wrench with an extension. just put the extension in the little square hole and start turning.
Noefearsupra
Ohio
+1
I'd just unhook the fuel line from the rail put a hose on it into a can then jumper the fuel pump relay, if you pull the drain plug you better have a 30 litre+ container ready as there's no stopping it once the plug is out short of getting a gas shower...
bioskyline
1,236
powell river bc
Mynes_3
135
cencal
forgot to do this when i took out the motor lol
Mynes_3
135
cencal
IJ.;1773946 said:
Just need to power up the fuel pump relay, much safer than a Gas Bath ;)
explain please? i think i know what your trying to say but i want to be sure what your saying lol
tfhorst
62
pittsburgh
So I am taking a gas bath by pulling the plug on my tank tomorrow. No choice. Looking for suggestions on what to catch half a tank of gas in.....lot of gas. And I am onlt going to. Be able to raise her maybe 2 foot.
destrux
1,183
10
PA
Buy a pair of chemical gloves and stick the plug back in when you fill a gas can up. Use a few 5 gallon gas cans and a funnel, or maybe buy a few of those 5 gallon oil change pans that have a closed top and a built in funnel. You'll still make a mess. The gas just pours out so fast.
toyotanos
What will we break today?
2,841
Coon Rapids, MN
First thing you do is disconnect the fuel line and direct it into a bucket. (big hose and gas cans help here)
Go to the diagnostic connector under the hood and connect FP to B+ and turn the key on. That turns the fuel pump on. Watch the gas pump stream, once it starts to peter out pull the pin back out of the diagnostic connector.
To be honest I would never suggest draining the tank with the plug on the bottom, they always seem to leak afterwards. I've pulled a full tank down by myself and while its not the easiest thing in the world, its far from impossible and saves from the leakage! (i.e. doing the job again)
Mynes_3
135
cencal
mind i get a pic of where the fp meet b+? thanks for the info tho.
Greek
513
Ohio
I drained about 9 gallons of gas from the drain plug. I ended up using lots of buckets/gas cans. It is pretty messy and a shitty process. It is quick, but I would go about the cleaner way of doing it with the fuel pump.
Also, don't throw your glove into the wind and have it be blown into the huge ass bucket of gasoline. BTDT.
