GARRETT GT35R
johnverheij
shoarmateam member
Nov 21, 2006
64
netherlands
hi guys,
i want to buy a garrett gt35r turbo for my 1jz
i'm driving the twins right now but want to go single
i know that the gt35r is a good choice but wich a.r is best for me?
my goal is about 550 hp
tissimo
Stock is boring :(
Melbourne, FL
Jay (suprahero) has a GT35R w/ a .82 (t3) A/r on his and made 543whp
I would consider a 1.01 a/r or a .68 T4 housing though for extra top end flow (and hp)
da89soup
World I Am Gay Blue!!!
Dec 2, 2005
1,978
Fargo ND
Jay loves his GT35 but I know he hated his ebay manifolds. Jay burned through his first ebay manifold and ended up going drewgo with his latest build. Jay was telling me the difference in quality is unreal.
Andre
115
Netherlands
Then you must go with the GT35 Turbo bacause thats a T3 flange
I thinks the GT35 is a Nice street Turbo for the 1JZ engine
Andre
115
Netherlands
unreal.
Where i can buy an drewgo manifold ? Link? Online shop
There's NO DIFFERENCE between a T4 flanged GT3540r and a T3 flanged one other than the Flange, the Wheel and nozzle are the same and that's what set's flow.
This is a common misconception Tiss ;)
tissimo
Stock is boring :(
Melbourne, FL
put a 2" exhaust on and see what happens.. Cut the size cut the flow= cut the power
larger a/rs allow it to breath easier..
I'm talking about a T4 .8ar and a T3 .8ar GT3540r housing
they both flow the same as the "Nozzle" size is the same and it's the restriction NOT the flange.
"It will only flow as much as the point of greatest restriction"
The only reason for the 2 housings is so you can bolt it to a T4 header without an adaptor.
tissimo
Stock is boring :(
Melbourne, FL
oh, I've always though T3s were smaller then t4s given the same a/r ratios.. looking back at my post a 1.01 t3 and a .68 t4 is a bit drastic, i should of said .84 T4 or wahtever it is.. But if they're the same then never mind. Never looked into it that much
tissimo
Stock is boring :(
Melbourne, FL
interesting.. I guess I never read up on it.. I just assumed the T3 Turbine housings are smaller in physical size so the radius would be much smaller, then the ratio would be different per the size of the turbine. But never compared two of the same turbine wheels I Guess, always T3 wheels vs a P trim Turbine.. good to know then.. I'll recomend my bro a .63 t3 then for his 1jz 240
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
Just a few weeks ago I had a T3 gt35 in the 1j 240sx and it pulled nicely up top. However I find it that an automatic JZ will benefit from a .63 T3 gt53 better than a 5sp. Recently I changed it to a T4 .68 and the difference is night and day. A little more lag, but hold on to your nutz cuz itz a wild one.
