Furious But Lazy 7M owner who gave Up.
Turbo Habanero
4,229
Tucson,AZ
IJ.;1924038 said:
Where did they go?
Doesn't sound right to me that's HUGE!
I wish I knew lol ..
I'm missing I think 4 that I know of.
There's 11total or supposed to be including the 2 on the starter.
Let me double check what size socket I used to take the bolts out.
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
The top four are 17mm heads and the rest are 14mm heads.
2 on the starter should be M8x1.25 12mm head
If it's like the 7M the Bellhousing to block should be M10x1.25 14mm heads
If it's 17mm head I'd guess M12x 1.25
(thanks Gurley)
Use some Loctite this time... :nono:
Turbo Habanero
4,229
Tucson,AZ
(thanks Gurley)
I was not the one that installed it last time... and Steven said he used Loctite on everything.
George confirmed the whole 17mm and 14mm by going to look at his motor. He said the 17mm was about 2inches in length and the 14mm was 1.5inches
87supraguy
808
Tucson, az
Jordan's clutch pedal went completely soft and doesn't seem the clutch I disengaging.. This maybe the reason he's been having issues with 2nd gear in two different transmissions now... Anyone have any ideas?
