Oh ok just making sure. If you needed it or something it wouldn't have been a problem.Turbo Habanero;1870296 said:keep the fan ?I'm not keeping the fan I sold to you I sent it out already I thought I pm'd you the tracking
Let me do that again
Turbo Habanero;1870575 said:So today i'm helping a friend install a AVC-R into his 1JZ MA70 and have a question for you guys
I've found every wire on the harness side but the tps or throttle signal wire.
Here is the Avcr wires
Red (power)
purple (rpm or injector signal)
Green (ground closest to ecu)
Black (ground farthest from ecu)
Gray (throttle)
White (speed signal)
and the two links Andy provided in his JZ swap guide
http://www.supramania.com/forums/showthread.php?43888-**How-to-wire-a-soarer-1JZ-into-MA70**
http://www.supras.nl/index.php?option=com_content&task=view&id=38&Itemid=54
Turbo Habanero;1871030 said:prep for engine bay paint.
