Furious But Lazy 7M owner who gave Up.
redhot91gt
Grenade Builder
Nov 9, 2008
126
Mesa, AZ
Turbo Habanero;1870296 said:
keep the fan ?I'm not keeping the fan I sold to you I sent it out already I thought I pm'd you the tracking
Let me do that again
Oh ok just making sure. If you needed it or something it wouldn't have been a problem.
Turbo Habanero
4,229
Tucson,AZ
So today i'm helping a friend install a AVC-R into his 1JZ MA70 and have a question for you guys
I've found every wire on the harness side but the tps or throttle signal wire.
Here is the Avcr wires
Red (power)
purple (rpm or injector signal)
Green (ground closest to ecu)
Black (ground farthest from ecu)
Gray (throttle)
White (speed signal)
and the two links Andy provided in his JZ swap guide
http://www.supramania.com/forums/showthread.php?43888-**How-to-wire-a-soarer-1JZ-into-MA70**
http://www.supras.nl/index.php?option=com_content&task=view&id=38&Itemid=54
IndigoMKII
2,181
Madison, Virginia
Red (power)
Gray (throttle)
Slightly OT on your own thread, unusual.
What are your plans for the 1j swap by the way? I mean your goal.
Turbo Habanero
4,229
Tucson,AZ
Yes I know but I didn't want to start a whole new thread for it when I know someone like Andy can awnser this simple question in a simple second.
My goals idk really just to do it right and shoot for over 500whp
IBoughtASupra
4,455
Queens, NY
What JZ ECU is it?
Supra has it on pin labeled VTA on plug M in the diagram.
I will have to look up the Soarer. The pinout or it is in the thread. I'm not home, I will take a look when I get home.
Turbo Habanero
4,229
Tucson,AZ
So back to my car still looking for the Oil Level Sender block off plate and can anyone tell me what goes into the OutSide of the valve cover (with oil cap) because i just have a hole no plug or rubber piece of any kind.
Turbo Habanero
4,229
Tucson,AZ
K thanks Andy.
So I painted my valve cover wrinkle black..
Turbo Habanero
4,229
Tucson,AZ
I know its not the best but atleat its one color lol.
It temp until I can afford to buy a new shell that's to my standards.
Imo it looks worse in photos
