Couple of ways, you could try and undo the drain in the bottom of the tank but I see you live in the snow zone so more than likely it's NOT coming undone ever again
You could syphon it out through the filler neck or you could unhook the fuel line at the J tube on the side of the block jumper the pump relay and let it pump through into a can and use it to wash parts.
I'd buy a few qt's of metholated spirits (denatured alcohol) and tip that in before you start as it will bind to any water in there and help it's removal, once the pump sucks dry tip another gallon or so of gas in and repeat then change out the fuel filter and you should be good to refill it.
One thing to take from this trainwreck of a thread is you don't get a second chance with a Turbo 7M they're an unforgiving bitch at the best of times, one good rattle will ruin your day and suck your wallet dry, gas is far cheaper than a rebuild.
