I'm in the market of buying a Bosch external 044 pump. I see that it's recommended to run these inline between your intank pump, and fuel rail.
What if the stock pump dies? Will your flow rate to the fuel rail lower? If you have your car tuned to a certain flow rate and suddenly it drops wouldn't that be harmful? Maybe I shouldn't be so concerned with that cause I'm only aiming for mid 400's, and that Bosch pump alone will easily support that.
I'm going to have to take my fuel tank out and get it cleaned out cause my car has been sitting for a long time. I'm going to replace my fuel lines too. What size fuel lines should I go with that would give me some head room just incase I want more than mid 400's down the line?
EDIT: Is there some kind of website that can explain free flow rate and pressure (psi). How can you determine how much HP a fuel pump can support.
