Fuel Pump doesn't prime in START position
TurboWarrior
Canada
I use a switch that goes directly from the battery to the starter because my wiring is bad at the ignition.
Since installing the switch I always start the car like this (when it is cold). I turn the key to START for a few seconds to run the pump. Or else there isnt enough fuel to start the car.
Now suddenly the pump does not come on when I crank it. Why would this happen? Now it takes me 3 tries to get the car to finally run because there isnt enough fuel pressure when it is cold.
What should I do?
mkIIIman089
Ohio
Or if you want you could rig it up even more and jump B+ to FP (I think thats it) with another switch.
What you SHOULD do is fix your wiring.
TurboWarrior
Canada
I wont have money for a few years. If the car keeps getting worse ill just be storing it. I have to do the HG for a second time this fall so i wont have to worry for a while. Thanks. I just found it wierd that all of a sudden it stopped doing it.
TurboWarrior
Canada
you are right. But I bypassed the starter with a switch so the started doesnt go when i turn the ignition. But the fuel pump still does. Well it did.
Im going to look through my shop manual wiring diagrams today.
TurboWarrior
Canada
The stock wiring is in tact. I ran my own harness from the battery to the starter for the switch. I have never messed with the wiring. This stuff is failing on its own this year. I thought maybe there might be another explanation but i guess its a coincedence that both wires have gone bad at the same time.
