Fuel. Dual Walbro or Aeromotive a1000 external?
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
I run the A1000 with -10 an feed and -8an return with a stock fuel rail, oem sumped tank. I sumped the front of the tank so the cops dont see it and painted the pump black. But i do do keep my tank at least half full of gas so i dont have no Fuel issues.
empera
Authorized Vendor
Philly.
thank you sir, very appreciated...time to buy and weld up a sump ;)
6,653
Canada
I assume you have an adapter for a -10 feed up to the rail, the rail will only fit a -8. (too think for a -10)
funky_monkey58
Closing in on 200+MPH
Apr 3, 2006
1,307
St.cloud MN
I did mine the regular way and sumped the rear. My supra has a pretty body I figure it kind of sets it off as a "don't mess with me I will tear your face" sign.
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Dual Walbro's = too loud for me. In fact one is way too loud. The sound is grating to me.
I use an A1000, no sump, (bottom feeder, so I gotta keep plenty of gas in the tank) and I made a metal cover for it that's under coated and lined with dynamat. You can't even hear it.
empera
Authorized Vendor
Philly.
Any pics
empera
Authorized Vendor
Philly.
got the a1000 pump today along with a SX filter...i should be putting this filter before the filter and after the tank correct? i was told different from someone else....unless i should be using 2 filters...also wat number micron should i use?
sorry for the noobish questions...just wanna make things clear.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Thats how mine is also aeromotive with AN -10 off the bottom of the tank its -10 all the way up to a "Y" then it breaks down to 2 -8 on the "Y" which feed the rail from both ends.
For the return I use the original fuel line both of them!
I use the old fuel return line + the fuel feed line minus the filter of course which is Y'd in from the regulator the evap line is still the EVAP like oem.
I hope this makes sense and is not to short.
empera
Authorized Vendor
Philly.
lol...sorry man been a while.
so it looks like sx performance discontinued the 41001...which is the one i got from a friend, so i cant really find filter replacement elements...
empera
Authorized Vendor
Philly.
pics if possible?
empera
Authorized Vendor
Philly.
u guys using the a1000 pump, how do you have it wired up? are u using the pump controller? stock wiring? etc...
