fuel cut!?!?!
T34418L3ONE
Supra for brains.....
Jul 3, 2005
225
Pleasanton
alright i cant help but to hit fuel cut. I have a mbc (hks) and i cant turn the boost down. I have a downpipe, catback, and hks intake? help please?
rakkasan
Currahee!!
Fort Campbell, KY
You can't turn it down because your mods are letting the air flow trhough your motor too fast. You might be able to raise it a little by backing the air screw out some (on bottom of your stock AFM). If that doesn't do it, it's time for fuel & air mods.....
shaeff
Kurt is FTMFW x2!!!!
11
Around
pressure test the intake system. :) or, look for cracks, splits, loose couplers, etc...
-shaeff
T34418L3ONE
Jul 3, 2005
225
Pleasanton
i have a wideband, but i cant stay in boost long enough to tell due to the fuel cut. Shaeff what would i do to pressure test it? hook up an air fitting somwhere in the intake trac and just put a plate over where my air filter hooks up?
shaeff
11
Around
get a piece of tubing that fits over the turbo inlet, clamp it there, go to home depot, get a PVC pipe "end" (the ones used to block off the pipe) drill a hole in it, put a valve stem in there, clamp it onto the other end of said tube, and pressurize with 15-20psi, listen for leaks, hissing, etc... you could also drill another hole in the end, and put a pressure gauge on (like a compression check gauge, the screw in type, with it's valve stem REMOVED) so that you could just watch for pressure drop as well. :)
-shaeff
