fuck man......i got a coolant leak in the worst possible place possible!
chefma70
404
Florida
the main coolant hardlines that run around the whole block. the one what runs directly under the turbo manifold wraps around the back of the block by the fire wall and ends under the intake manifold. its about a dime thick.
there are two ways to fix it first is take the head off. :3d_frown:
2nd is raise the motor 3-4 inches and slide it on.:3d_frown:
anyone else ever have this problem ?
how did you fix it?
92nsx
2,957
Clearwater, MN
BTW what is the -1 all about?!?!?!?!?!?
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,965
I'd be all about the JB Weld too. You wouldn't have to remove the head but you'll have to remove just about everything off of it. So how's the headgasket? Might be a good time to replace it if you decided to replace the coolant pipe.
Satan
Tampa
Are you sure it's that hardline and not the hose at the back of the head? I'd never seen that hardline break/leak, but it's possible.
Instead of all that other work, if you know the exact spot and can see the hole, it may be easier to wrap a piece of heater hose over it and clamp it.
mkIIIman089
Ohio
tissimo;1439345 said:
If it is the hardline, I'd look into why it failed. Metal just doesn't develope a hole for no reason.
Even really rusted out systems don't typically rot out those metal coolant lines.. on any Toyota. So this is a good point.
Justin727
T-virus infected
The flange to the water pump housing on that hard pipe did rust and leaked at that flange atleast for me
What I did was I sawed it off and about an inch of pipe sawed of with it. Had it brazed together. Then used some marine hose with the metal wire wrapped thru the rubber itself. Installed the house coupler and the repaired piece and it held up well till I pulled the motor for the build. Bought a new one and repalced it.
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
andrew ANDREW!! THE REASON WHY is because it was rusted big time i hate to say this but i told u so!! lol [dont use that old rusted crap] ill come over and help u take the head off.
u still have the N/A Hardpipe right? if so lets use that one. and while we are there lets check the hoses im pretty sure they were nice and tight.
Failure14
276
Ohio
My same hose popped off a few days ago and i just stuck my hold hand
behind there from the turbo side and had a friend grab the hose and feed it to my
hand and it took no more than 5mins tops.
Thats IF the host just popped off...
And i agree with everyone else i dont really see the hardpipe
just rusting away like that...
Satan
Tampa
There's a similar pipe for the 2J and I had even thought about replacing it with a steel braided hose. When I put the single on my 2J, I had to plug a couple of the ports with the heater-hose-rubber-caps and I know they will eventually leak.
So, I thought about finding a better way to reduce that risk. I've been told to just stay with that piep, but knowing the work ya'll will be doing to replace it, makes me wonder wha options I would pursue first.
Just an idea, but if you could use the bends from the hardline, it'd be easy enough to clamp on some hose to make that bend behind the head. It is a 7M anyways (cogh, cough), so save that extra time and put towards your eventual 2J swap ;-)
Anyways, just thinking of options for ya.
Good luck!
