Front Sub-Frame Swap Question
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
Do you mean that on my 90 with the 87 crossmember I'll have to make sure to put pre 89 motormounts on it? Or that I'll have to put 89+ motormounts in the 87 so that a motor can be dropped in easily? I don't think I'm following you completely Robert.
Adam
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Poodles has it correct, I'm swapping all the stuff I want from my 90 and 88 into my 87. The 90 already has a 1JZ with R154. And the 87 still has the stock sub frame. I'm want to back date my 90 because I will need to put a sub frame back into it once I remove the stock one so that it can move. I don't care about my 90 or 88, just certain parts in them. I'm not going to be putting a motor into the 90, so the motor mounting brackets are of no concern to me, just steering and rolling. So as long as I put the 87 sub frame into my 90 and have it roll and steer, I'm happy.
Adam
square mounts aren't as smooth as the later style (2J's are stiffer than them as well IIRC)
or it could just be the 7M crank....
Haven't tried dropping an engine in with the later style, but the square mounts are easy to drop in...
