front end of MKIII converted to toyota chaser???
PROJECT N00b
XBL: Mkiii DriFt3r
May 22, 2005
1,660
honolulu, california
i saw a picture of a Mkiii with the front end converted to a toyota chaser...and i was researching on it, i found out...which some if not most of you know that, they share the same engine as the twin turbo model mkiii in japan, so maybe i was thinking that it should be possicble to change the front...and i bet some of you reading this are saying, why would you do such a thing? well because i may want something different. so yeah i just want to know if its a play and play kind of deal...because if its the same then it should be easy right?
thanks
SupraManDrew87
Picture Me Rollin
Apr 4, 2005
26
Tucson, AZ
I'm not sure how many there are, but there is more than 1. :love:
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
Mint, I thought I'v seen more then just that black one!!! I think thats a cool convertion and it sounds easy to do.
PROJECT N00b
XBL: Mkiii DriFt3r
May 22, 2005
1,660
1TuffSupra said:
Last I heard it all just bolts right up in place of the stock pieces. Someone correct me if Im wrong, but that is the understanding that I had
so...well thats what im thinking too, because if it uses the 1jz then it should right? you guys get where im going with this i assume...
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
You sir, are wrong. There are no fenders that will bolt up, the hood had to be modified as well I believe. The mounting points are probably close for other stuff, but you're looking at a LOT of modification and work to get it to fit at all.
shaeff
Kurt is FTMFW x2!!!!
11
Around
that's the ONLY way i'd EVER have flush headlights. :)
-shaeff
