Front Brake Issue
JORAMI17
64
FL
Hi Guys, I have a 91 Supra 7M-GTE and it pulls to the left when I step on the brakes. I was told my problem was on the right side and so my caliper stays engaged even after I let off the brake pedal.
I changed the passenger side caliper and hose already with no luck, I also changed a block with 4 brake lines that sits in the inner fender underneath the master on driver side and still no luck.
I don't know what else to do...:: angry ::
Anybody gone through this...please help!!!!
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
Yea brakes can definitely be funny. Buddy of mine made a brake setup on a Jeep Cherokee. Swapped dual piston calipers off a Grand Cherokee or something. Anyway, new master cylinder, no abs modules, couldn't get the brakes to bleed correctly. Every time he had an ok pedal, he would start the truck and the pedal would go to the floor. Must have put a gallon of fluid threw the system.
I still think somehow there was air trapped in the master, even though he bench bled that also before installation.
JORAMI17
64
FL
turbotom88;1498500 said:
hi, i work at a brake shop and i agree check the sliders and make sure the pads move freely in the housings..... good luck
Thanks again, I'll probably check it out this weekend.
