I cannot remember how exactly I did mine, but IIRC all I did was connect one side(comb switch side) of the fog light switch to common ground, and left the other side connected to the relay. Then run switched power (tapped of the cig fuse) to the other side of the relay, which is normally powered from the headlamps. Makes the fog light switch a ground side switch for the relay, and leaves the entire loaded part of the fog lamp ckt alone.
