Flex-a-lite wiring
Schiffer
Ok I installed my fluidyne radiator and flex-a-lite electric fans the other day. I did not get the control box, but this is how I tried to wire it. I ran the negative wire of the fans to the same ground as the battery. Reading from the SOGI write-ups, I tried tapping the positive end into the yellow wire coming from the solenoid resistor. When I started it up, the fans ran slowly, and the engine had a lumpy idle. Then I disconnected the positive end for the fans, so it was back to normal, and it ran fine. But when I touched the positive of the fans to this yellow wire, my problem would reoccur. How do I need to hook up the positive end of the fans? Slightly baffled here. Any help would be appreciated. Thanks.
Steve_N
Louisville KY
After several wiring mishaps of blown fuses, burned wires & 2 or 3 control boxes within the 1st yr with my FAL 210.s I wired mine into the stock condenser fans wiring. I also wired in a control switch as specd. in the SOGI mod so I could turn them on at will or when the operating temps went up they would spin on there own. Ran them like that w/o any problem. 4 yrs later rubber insalator deterated & fell loose into one of the fans & locked the fan motor up.
Schiffer
I'm looking to wire it up somewhere in the engine bay. I had thought about wiring them to the stock electric fan wiring, but there isn't much room to cut and splice. Now if I did this, would the fans come on with temperature like the stock one?
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
Mine are wired directly to the battery, on a relay to a keyed source.
I can't seem to find a quality relay that can handle the constant use of the fan, they always seem to fail every few months. I need to find something OEM that can take the heat.
Steve_N
Louisville KY
Schiffer- No need to. I just cut off the connectors from the small elec. fans I removed from the rad to install the fals & pluged them in. After the Fan motor gave out & I went back to the stock set up I just replaced the connectors. & Yes they will come on at the stock set temp. Remember I also wired in the SOGI mod to turn them on anytime.
Ric- Yes I ahd the same problem & thats why I wired them as described in my 1st post.
