FIPG?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Gotta go with SH on this. I guess it would depend on how long it sits but even after it's completely set up (which takes longer than an hour) it becomes little different than any elastomer type gasket. It'll still extrude inside the joint. If I can't clean off the excess I let all viscous sealants set up a bit to keep them from extruding outside the joint where they can later break off. That and I use very little. Since the space between the parts after they're tightened is tiny there's no need to go nuts with the stuff.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
All the stuff suggested here works fine as long the job is done right. There's no need for special dealer stuff. It's not rocket science, all you're doing is sealing between two surfaces. There's lots of ways to skin that cat. Do you know how the crankcase halves in piston airplane engines are sealed? They run a length of silk thread or synthetic string around them. It's the only approved method because it prevents a loss of preload on the bolts holding the cases together. In a pinch I've used the same technique on cars. Not that I'm suggesting you run a string around your oil pan but in other places as long as the surfaces are clean, flat, and reasonably close tolerance something like fishing line works fine. No other gasket is needed.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Yeah, it's not something you'd do often but nice to know. I roll almost all of my own gaskets these days but in a pinch tacking some line around a clean surface with a few drops of super glue (go inside the bolt holes) and slapping it on usually works fine on everything from oil to coolant. Works perfectly on stuff like the TB and ISC valve. Easy to remove later on too.
There's lots of such tricks. What do you think we did back in the days before the MHG came along? I can tell you how to run high boost all day long on a stock HG using nothing more than a roll of stainless safety wire, a propane torch, super glue, and an electric engraving pen. Never tried it on a Supra but it worked great on other cars. Sometimes I feel youngsters must think performance mods didn't exist before they were born and everyone drove Flintstone cars.
