Hey I am wondering if anyone has found a more compact clutch that will work on the 7m.  The reason I need one is I have an aftermarket radiator that is 52mm thick compared to the stock 25mm thick unit.  The fan sits to close to the shroud and has ripped it up and damaged the fan blades and probably the clutch.
