Ever seen a turbo setup like this?
AaronsSupraMKIII
254
Athens, AL
IJ. said:
Think of it as stuffing a 1/4 pounder into a junior burger so you can feed it to a toddler so he can bench press 400 lbs ;)
LMAO that is about the funniest thing I have seen on here! :biglaugh:
Deffinetly quote worthy!
89turbosupra
163
oxnard
Those turbos are form a 4.5 diesel LCF. Those little things boost great. You have 10psi by 1200rpms on that motor. The funny thing is in the 3rd picture down you see the oil feed line and a blue sticker. That sticker says: don not use this as an engine lift
Wills7MGTE
( . )( . )'s RULE!!!!
May 12, 2006
1,077
Jackson, MO
With ARP it should work, all ya need then for 50PSI outtab eohhhh IDK maybe 2,000cc injectors and maybe some 1200cc secondaries and god himself should put the engine back together just to be safe.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Those setups are made for the Dodge Cummins trucks as well..Guy in my town had one..with a 5" stack comming out of the hood..
Diesel engines are about the only thing that can handle that shit.. The 5.9 cummins crankshaft weights around 125lbs IIRC.
marc3
canadian blood
Jul 19, 2006
229
quebec,canada
actually, i've only seen this on tractors that do drag pulls.
some even have 3 turbos staged in this manner , they can have manifold pressures of 240psi ansd up!!
AaronsSupraMKIII
254
Athens, AL
SevenMKIII said:
Weird, I remember him making a thread on this very topic some two weeks ago...same pictures and all.
Actually the other thread was about a variable vein turbo. Might have thrown a pic of this one in that thread though, dont remember.
