Engine Harness Cover thingy? (Piece going over valve covers)
JDMMA70
2,550
Houston
Did Toyota make the little black enclosure thing that protects the engine harness as it goes across the valve covers? Has anyone made an after market piece? Mine is going to shit. If i knew what this exact piece was called searching wouldve been easier :biglaugh:
Anyone do anything creative with theirs?
Thanks
~JDMMA70
Wayne G.
87Turbo 5sp Targa
Apr 19, 2005
213
Gainesville,Ga.
Thanks
~JDMMA70
This only comes with a "new" enging harness. It is not listed as a seperate part. I had to replace mine with 1/2" plastic wire wrap like used on the rest of the harness, it fit snugly across the timming cover in the same place.
Pantaloon007
Permanent Ban
Apr 2, 2008
76
Vegas
j3pz;1073220 said:
my 87 has it also
As did mine, but it was falling apart so I took it out. I have seen a bazillion pics w/ that piece missing, so I figured it wasnt critical.
I think the PO has the same ? I do- Is it critical?
Justin
Speakers?
Spokane, Wa
I have one that's in amazing shape. I had to take it off when I routed my harness with my FFIM.
shoot me a PM if you'd like to buy it.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
If I had a little bit more manufacturing know-how, I'd be on this like a horny college guy on drunk cheerleaders...
A basic square pipe with heat insulating wrap and a few bracket pieces added would do the trick. Or better yet, a piece dipped in some sort of heat insulation (not sure if that exists) would be sweet.
...Or you could just buy a $0.50 piece of plastic wire loom...
JDMMA70
2,550
Houston
starscream5000;1073245 said:
maybe if you got enough interest gathered for this part and money up front from each person, ARZ may consider designing a blinging piece for you...
Hmm i wonder how many people would actually want one
Sent
Well that makes two people so far whod want one.
Koenigturbo
1,336
Oxnard CA
I made from black A.B.S plastic face plate that stereo shops use when they in install stereo's in cars that need to fill extra space or fill in gaps. My fits better when I have my coil cover installed it nice and tight ,it looks factory. here's a picture: (if I can load it up) The edges are actually pretty smooth, it just looks weird because my coil covers not on it.
