emergercy brake shoes?
Jeff Lange
Administrator
4,922
12
Sunnyvale, CA
jefflange.ca
$50.64 - 46540-14020 - Front Shoe (Same for both sides) ($25.32 x 2)
$27.84 - 46550-14020 - Rear Shoe (Right side)
$25.32 - 46590-14020 - Rear Shoe (Left side)
You're looking at about $100 for all 4. If you order from a dealer that gives a good discount, expect to pay about $7 less for each shoe. Have fun. :) Just a note: these shoes aren't really supposed to be a regular maintenance thing, so if they're excessively worn, make sure your cables are releasing properly, etc. Either that or you like to pull your e-brake during normal driving or something ;).
i_zombi
DRAGULA
Aug 15, 2006
27
Pittsburgh PA
Thanks for the info guys!
Its my first Supra and I'm learning alot from everyone on this forum.
Much appreciated.
Dan
Wayne G.
87Turbo 5sp Targa
Apr 19, 2005
213
Gainesville,Ga.
i_zombi said:
I have it adjusted as far as it will go.
There is also a slot in the hub of the rear rotors - use a brake adjuster tool to turn the star shaped link inside (they adjust just like old drum brakes) till the wheel does not turn then back it off 4-5 clicks that should do it---
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
so how bout if i hear a jingling in my rear left tire? is a spring loose back there or somethin?
jamesdem1123
98
Palm Harbor
yea i need the e brake shoes as well... when i changed my pads the braking lining (?) on the ebrake pads just kinda fell off. i have an auto and never use the ebrake but im gonna convert to standard so ill need them eventually...
