Dyno vid 515 rwhp, 503 tq Project Cherry Widebody, stock 7M-GTE internals and ecu!
Zazzn
l33t M0derat0r (On some other forum) n00blet here
Toronto/SF Bay area
Forget the standalone, there is another problem there and I'm not sure if it's the tune.
A few degrees of timing isn't going to make 200 hp go missing.
The sp61 dyno was on pump gas as well... Do you think you have a boost leak maybe?
Dec 3, 2003
6,653
Canada
Brad, remember how the boost was set to read on the dyno? I mentioned that to you. It was higher on Dave's car since they hooked it up different. I personally think it was wrong and you were at lower boost.
I think you are missing some info here for this turbo.
He has an engine that is stock, meaning head. This would add power.
He dynoed it in almost 100 degree weather, added power there and has no stand alone. Add these up and it will be a better number.
Duane
