Dyno vid 515 rwhp, 503 tq Project Cherry Widebody, stock 7M-GTE internals and ecu!
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Great numbers!
Explain to me though how you get 28+psi from the stock ECU and electronics on a large turbo without hitting fuel cut??
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Fletch124;1373695 said:
Great numbers!
Heh! 50 psi base fuel pressure on 550cc injectors, plus water/meth injection adds fuel; pulling over 20% fuel on the SAFC :naughty:
)Law(
53
PA
NicE numbers. By the way how many mk3 's you work on a day??? I spotted on a lift in the background
tekdeus
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
kotu100
1,899
Easton, Ma
OMFG thats sick!!!
i have the exact same setup, minus the water meth, and a 64mm turbo.
thanks for once again instilling faith into the 550/lex combo.
whats that turbo got for a hotside? i see on the dyno graph you're gettin 25psi right around 4500rpm, where does boost kick in on the street?
tissimo
Stock is boring :(
Melbourne, FL
Get a standalone, thats a lot of boost for very low numbers. I suspect the ecu is detecting knock and throwing it in limp mode.
tekdeus
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
kotu100;1374541 said:
OMFG thats sick!!!
It's a .84 T4. I'm using a quick spool valve and in 4th gear on the street it hits 15psi at 3600rpm.
Zazzn
l33t M0derat0r (On some other forum) n00blet here
Toronto/SF Bay area
i agree pulling -20 form the s-afc fubars the timing map.
I also had low numbers because of this when i did 453 @ 24 PSI on a sp63 back in the day..
Sounds like fun and sounds really good man.
You should look in to an emanage if you don't want a standalone at least you can clamp the AFM hz at 1550 so you don't hit FCO then add fuel by changing the injector pulse width... You can also adjust the timing to add or remove!
**edit**
wow that's pretty lazy vs the SP61 GT I tuned on a 7m.
he had 420 @ 16 PSI with an emanage. Later when he tuned to 20 PSI he was over 500! He also had 440 FT tq at 4100 RPM on 16 psi!
I have the winpep files if you are interested in seeing them.
tekdeus
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Zazzn;1375161 said:
wow that's pretty lazy vs the SP61 GT I tuned on a 7m. he had 420 @ 16 PSI with an emanage. Later when he tuned to 20 PSI he was over 500! He also had 440 FT tq at 4100 RPM on 16 psi!
Sure I'd like to see the difference the tuning made vs the stock timing map. I'm also wondering if the dynos I used for testing are loaded properly for my car. I see 15psi at 3600rpm on the street, but the 2 dynos I have done seem to show much later spool.
Zach
ECUMaster USA
Apr 6, 2005
375
TX
No doubt. Numbers seem reeeeeeeally low for 28psi. Are you sure your boost gauge isn't fubar? Turbo does seem awfully lazy on the dyno, as well.
All that aside, those are some fun numbers and there's definitely a lot of power left on the table for when you go standalone.
tekdeus
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Zach;1375488 said:
No doubt. Numbers seem reeeeeeeally low for 28psi. Are you sure your boost gauge isn't fubar? Turbo does seem awfully lazy on the dyno, as well. All that aside, those are some fun numbers and there's definitely a lot of power left on the table for when you go standalone.
The car is only tuned for pump gas + water/meth at 22psi (SAFC, 8 degrees base timing), and I simply ran a mix of pump and C16 for the dyno at higher boost just for fun. So the power left on the table may be from not enough timing for 28psi and 100% C16 fuel. Looking forward to running a standalone soon though.
