Dyno: 1JZ Single GT35R and E85 602WHP/550WTQ
2JZ_MA70
191
Cleveland
OK final number is 602whp/550wtq !!! The impresive thing is the power under the curve... You can make peak numbers all day long and run slow on the track and the street that turbo is outstanding steet turbo for this engine
If it wanst for Tim at Switzer Performance (home of the world fastest Porsche 997 turbo) much of this would have not been posible. He helped me with the build and tuned the car. Man I still cant belive it.... I cant wait to drive it.!!!
Mods are: 3" turbo back no cat, Tub manifold with 60mm tial gate, 2.5" int tubing, 24x12x4 Int, 1600cc, Twin Walbros, AEM EMS and C2DI... that is about it. Stock motor. All bolt-ons.
But yeah the stock cams are definetly a limitation at this point. I can get them reclocked for top end...but its somewhat pointless.
We are building it with response and good street use in mind.
I posted some pictures on page 3-4
New vids of the track and one dyno run...
Trust_GTE
BOOST NOW...CRY LATER...
Apr 4, 2005
120
FL
How many lbs was this made on?, impressive for a 1JZ. 1600cc injectors, twin walbros, and a 60mm gate... man sounds like a set up for a big dog 2JZ.... I'm amazed how that worked, good job to the tuner.
Those are some awesome numbers for sure. I know mine should make that too with my 2jz bottom end, but I'm still trying to track down a leak. Hopefully I can find it today. Very impressive and definately get you some cams. I have the Crower 272 small core's and I love them.
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
tissimo;1137570 said:
Very nice, I'm surprised you were able to keep the power from falling off up top with the stock cams.
I agree, I basically have the same mods, Let see if i can touch 500hp..
Gritz
155
nc
Like i said on supraforums, why would you want cams with a awesome power curve like this he's making over 500hp from 4800rpm to nearly 8000rpm...wow!!! Even hits over 500wtq at 4600rpm..who says the 1jz is tq less???
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
wow very nice numbers and good curve on e85 what kinda clutch are you using?
92nsx;1138124 said:
:bowdown: I guess I can't smack talk the 1JZ anymore.
Well you can Rob but it'll be just like most of the crap talk here it'll be
a) Someone that doesn't actually have anything better
b) someone that doesn't actually have a running Supra
c) all of the above ;)
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
ROTFLMAO!!!!
Very very nice numbers! Certainly shows what the 1j is capable of.
