solardrgn;1907075 said:is there one to begin with?
Nick M;1907111 said:All radiators need a fan. I don't know what you mean. And aluminum doesn't transfer heat as fast as copper/brass, so you really need fans.
#04;1907130 said:pretty sure my koyo has the correct half round top mount
probably seeing standard photos rather than model specific.....
IJ.;1907124 said:PWR is a drop in replacement.
suprarx7nut;1907167 said:Mishimoto is rounded. THe closest thing to making it not a drop in was that the hose inlet/outlets were a tiny, tiny bit smaller. Normal hoses work just fine, but you may need to use a new clamp (you should anyways).
See below:
adampecush;1907209 said:koyo racing rad fits perfectly with the stock fan and shroud. just need a plug for the 1jz temperature sensor.
