Driveshaft Carrier Bearing
Island_Yota
264
Vancouver Island
So apparently this part doesn't exist, my last resort is the Toyota dealership. I got a really un-helpful person at the parts counter at a local autoparts shop.
Does this part exist in the aftermarket? Lady at the counter told me to start searching junkyards for supra's :icon_mad: . Any idea's on the price of it?
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Sad to say.. Junkyard is the way to go!!!
I replaced mine for free from a junkie... It works great!!!
Its a b*tch to get off, but it does come off!!!
Take off the drive shaft then separate it and the tail end with the carrier needs to be clamped down then cracked with a i want to say 24mm socket... and boom your ready to go!!!
JesseH
1,153
someone on here would prob. be more than happy to sell you one from a car their parting out. But if you were even thinking about spending the money on one from the dealership you would be better off spending the extra cash on a one piece shaft and never have to worry about replacing one again plus getting a little extra performance while your at it.
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Actually the AutoZone here in cali does sell one cheap, last I checked but you have to screw with it to make it fit right, as I recall it has something to do with the mounting bolts. I 'll search and try to find a link. I bent over for toyota when I replaced mine, but I'm sure the aftermarket one is just as good once you deal with the mounting problem (it's pretty minor iirc).
Island_Yota
264
Vancouver Island
iwannadie;1130539 said:
Is it just the possible vibrations or is there something else going on with 1pc?
Yeah, one piece is harsh on the pinion bearing and gears, aswell as the output shaft on the tranny, aluminum 2 peice would be an upgrade, 1 peice.. not so much, 2 piece is alot smoother do to the driveline angle aswell.
I want to keep it more of a grand tourer type of car that it is, not looking for performance over comfort.
Im going to find a hard time finding a supra in the junkyard and even then il have to jack it up, pull the entire shaft and buy it since its pressed on. Then hope I dont wreck it getting it off and the rubber will probably be bad anyway, im sure after a few hard launches it will die aswell.
Is the turbo bearing different than the N/A bearing?
gaboonviper85
3,236
Northeast Philly
it's called a "center support bearing" and toyota still had them!!! They are expensive as hell but yes they still have them.
That is why I went with a shaftmasters 1pc....it's been a great part so far and isn't noisy at all and doest vibrate.
It's bolted on not pressed.
iwannadie
981
gilbert, az
Thats why Im wondering why someone is puting down 1pc, Ive herd all great things about shaftmasters...
gaboonviper85
3,236
Northeast Philly
because a 2pc is "better"...but our transmissions aren't that far out of line from the diff so a 1pc works fine...and most trucks with really long driveshafts need a 2pc for obvious reasons...our driveshafts are short and stout so a single works and has been proven to work...so it's your call.
I'm very happy with my 1pc...looks like sex when I'm under the car!
PROJECT N00b
XBL: Mkiii DriFt3r
May 22, 2005
1,660
honolulu, california
Ok so I went to AZ today and they have this one
A2006
and this one
A6004
the latter cost about 178, is there a difference between the two or what?
To me, the only difference that I can see, is the mounting tabs.
Island_Yota
264
Vancouver Island
Ok, pretty sure the part number on these is 37230-22042, If you google that theres all sorts of Chinese manufacturers sites with them but of course, you cant just order one, you would have to order like 500.
Its apparently the same one used in the Cressida so that might make finding a used one easier.
Horsepowerfreaks.com has it for $257, and I would assume its about the same price from Toyota.. I would go 1 peice before I paid that much! :aigo:
Does anyone know if the MK2 used the same part? Its funny, I can find those online but I cant find Mk3 ones at a reasonable price.
heres one for a cressida on ebay, looks... wrong?
http://cgi.ebay.ca/1990-90-TOYOTA-C...VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
