downpipe question
hey guys i bought a trust mx 3" downpipe but the one gasket that fits inside the y pipe came a little small so i used the original. do u think it would leak? i tightened as hard as i could let me know soon before i install my motor tomorw. thanks:biglaugh:
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Well at least if you have an EXHAUST leak you know where to check first
My bad :p
supra90turbo
shaeff is FTMFW!
32
MA, 01440
If you're worried about it, just get a new friggin gasket. It's like what, $3 at the autoparts store? they won't list one for your particular application, and if you try to explain to an autozoner what the hell you're trying to do, you'll actually be able to see him lose brain cells as he tries to understand.
Go to a NAPA or something with the gasket and ask to see their selection of exhaust gaskets. You'll find one that matches up close enough.
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
If it does leak i have some Extra Gaskets in the Set i bought from Champion
I could send one to you, just cover the Shipping
Ninja Edit:
I put the DP on after putting the Engine in. was just easier for me to put it in. Used some RTV to hold the Gasket in place while i bolted it up. Not the easiest thing to do but doable
Also i think the 7M-GTE had the same Gasket on it's stock Exhaust don't know if they are the same size but i have some of those too
Ninja Edit:
do u have a picture and or measurement of inner and outer diameter of both gaskets? i would really appreciate it:love:
