DM oil sender hose
mkiiichip
1,434
WI
Well the line goes into a larger plug, so its not actually part of the block. If you dont use the line from driftmotion, you either dont have oil pressure reading, or you find somewhere else to put it. Like a sandwich plate on the oil filter housing.
shaeff
Kurt is FTMFW x2!!!!
11
Around
3p141592654;1631956 said:
I found that too, browsing around, but the following quote from the linked thread posted earlier makes me hesitant to try it. Maybe I'll just bite, as it's only a couple dollars.
bigaaron said:
NJsupraA70 said:
This is all you need
autometer part #2269:
I ordered this, it does not fit. It is larger diameter then the hole in the block.
shaeff
11
Around
There are other oil passages that would work. IJ had a picture floating around of where the oil/water passages were located on the exhaust side. I'm going to dig around for it.
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
Find that pic you were looking for? ^^
I think it would just be easier to run the 7M sending unit on the exhaust side, especially if you are getting the harness extended, it would not be too much of a hassle.
Sam
OneJArpus
2,798
86_sports_1jz;1632302 said:
so it only goes in a couple of turns and then you tighten it until it stops even though it feels like its gonna mess up the threads on the block? whats the alternative if you don't use the line from driftmotion?
i put the factory 2jz or 1jz sensor in the hole... Get a oil filter adapter plate and then put the 7M sensor in the port on the side of the sandwhich plate
nctexan
268
Houston
I have a DM stainless adapter line and a new 7M sender. I already have my 1JZ in the car with the AC compressor and radiator all hooked up. I didn't realize at the time how difficult it would be to get the DM line onto the block with the motor and such already in the car. Would it be easier for me to just get one of these "sandwhich" plates and put the sender on it? Also, does a wire connect to the sender or does a separate wire communicate to the ECU?
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
I would just remove the ac while you put it in. Doing a sandwhich plate will be just as, if not more difficult with your engine in-car.
A wire connects to the sender, Yes. Are you asking where the wire goes to?
Sam
nctexan
268
Houston
Yes, I was asking if a wire connects to the sender, and then where the other end of the wire that connects to the sender goes. It just doesn't look like there is any connection on the sender itself for an electrical wire, that is where I'm confused. So the wire connects to the little metal disc on top of the sender then?
te72
Classifieds Moderator
6,623
9
WHYoming
Appears to be like the oil sender in my Mk2, a 6m. If so, then there should be a wire with a connector that attaches to the little disc part of the sender you have circled in the picture above.
mkiiichip
1,434
WI
This kind of connector, connects to the top of the sender. And the wire would lead through the engine harness, to a connector in the ECU area. Eventually going to the dash.
nctexan
268
Houston
Thanks guys! mkiiichip, wheres a good place to pick one of those connectors up from? So the wire should already exist on my 1JZ harness then? And obviously, since my US 7MGTE has an oil pressure guage, I need to find where that wire goes to from the dash and splice that to my wire coming from the pressure sender, correct?
nctexan
268
Houston
ok so laughing is permitted. I put teflon on the DM sender hose before I cranked it into the block. I stopped trying to twist in in because my wrench started rounding the corners. What should I do? Remove the whole thing and use locktite? Leave it in and hope it doesn't leak?
87supraguy
808
Tucson, az
Question... Anyone have a picture as to where they are hooking this line up to? Reason I ask is cause I'm not sure if I have to remove the stock 1j sensor and that's where I would find the place to thread in the line.
mkiiichip
1,434
WI
There is no sealant needed on tapered threads (although some liquid sealer can add some peace of mind, leave the teflon tape for the plumbers), use a good quality line wrench to tighten the line, and it will seal how its designed to seal.
Sorry no pics, but yes you remove the old sender, behind the ac pump.
te72
6,623
9
WHYoming
nctexan;1668154 said:
Thanks mkiiichip! Can anyone confirm that the nut size on the DM sender hose is 11mm?
Top of my head, I can't. I would PM Aaron on that one, he could get you a quick answer.
Toyotasupra16;1682531 said:
Does removing the stock 1j sensor and using this hose cause any codes or dash lights to come on.
Nope, no codes or lights.
