Differential switch
jamesdem1123
98
Palm Harbor
i have an 89t auto which i think comes with a 3.73 rear differential. I heard that the N/A has a 4.30. is it possible to just switch them without having to mod it at all? how would i correct the speedometer?
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Then you have to simply deal with it. The speedometer drive gear is unaccessible from the outside of the transmission for whatever reason, hence, you must pull it all apart.
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
I think 11/ 12 inch rims will help the tires from spinning!!!! The NA diff. has other advenges like getting the ass end out easyer.
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
Both the N/A and turbo auto trans have the same drive gear internally so if you go with the N/A 4:30 rear, just get the driven gear from a N/A auto trans.
They are interchangable and is external (so to speek), its very simple to do. Just unhook the speedo cable down at the tranny and remove the driven gear assembly that the cable was attached to from the tranny (one bolt and it pulls out). Get the unit out of a N/A auto trans car from a auto salavage yard and put it in yours, hook up the cable and off you go with a correct speedo.
cjsupra90
Jun 11, 2005
1,029
Lakeland, FL
Jeff Lange said:
33481-24020 = N/A A/T Drive Gear
33481-30060 = Turbo A/T Drive Gear
Don't look the same to me.
Yes they are different part numbers, but they are both 6tooth worms and the driven is 18 tooth for the turbo and 21tooth for the N/A.
I put a 3.727 in a N/A car about 2months ago for a guy and just got the driven gear from a turbo car (33403-69195). It fit and works fine and the speedo is pretty accurate according to a local sheriff's officer.
Now whether or not they are meshing correctly, I dont know, but everything seems to be working fine. Knowing that they are different numbers, what the difference is, Im not sure, and I may have the guy bring the car back and I'll pull the driven gear out and see if it is wearing funny or anything.
tomjan87
121
Madison, WI
There is a box you can get. my car has it on it. Also, the gear is accessable. there is one bolt where the speedo goes in. you just have to find the right gear.
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
Ok, I'm taking out my NA 5 speed and put a turbo 5speed in with the NA 5speed diff. So would I use the NA driven gear or what????
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
What won't fit, the NA 5 speed driven gear won't work with the turbo 5 speed or the turbo tranny won't work with the NA diff???
