differential ratio's
willfish
been here since 2003
Apr 23, 2005
648
Pittsburgh, Pa.
what is the rule of thumb so to say ,
the lower the gear ratio the faster off the start ?
an higher the gear ratio the faster top end spead ?
is that how it goes ?
, I cant remember, an I was going to post a WTB rear end in the classified section ..
Will
willfish
Apr 23, 2005
648
Pittsburgh, Pa.
so , can I take a N/A or a pre- 89 an slap it up to my 90 ?
, I think I would be wanting something of higher ratio number so I could get a getter off the start ...
Will
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
BorHor;958068 said:
All turbos were LSD's. And most NA's had LSD's too.
I think MOST na's came with the NON LSD 4.30.
Your speedo won't be off that much but I don't know in which way. If you have a GPS I'd go off that. I put a 3.91 in mine but I still have the NA a340e in it so when test driving it last week I noticed it was different but couldn't tell if it was faster or slower than what I was actually going.
willfish
Apr 23, 2005
648
Pittsburgh, Pa.
you mean , that most N/a's were LSD ?
8,897
willfish;958057 said:
how bad was it off ? is that the only downfall ?
ohh an are all the differentials/ rear end LSD ?
Will
LSD was standard on the turbo, an option on the GE. I had 4 7MGE W58's, only one was an open diff.
3.91 is what percent of 4.3. Answer that and you know what percent your speedo is off. ( I only gave you that answer because I know a nuke is smart enough to figure it out)
gtsfirefighter
Sep 26, 2006
2,966
BorHor;958238 said:
Are you guessing? Because every single NA I have checked under had an LSD. I do know of some with out though.
No because every single NA I've had and have looked at did not have one. I'm sure someone here can produce the numbers but IIRC LSD only came on sport models na's.
Eple
Narf
Jan 30, 2007
10
Canada
Not to hijack the thread, but i've got a quick LSD question. Our stock turbo LSD's were VLSD's, and not clutch type, correct?
