Diff. between Mk3 and MK4 engine?
Wayne G.
87Turbo 5sp Targa
Apr 19, 2005
213
Gainesville,Ga.
This to all the real Supra techs. What was changed about the Mk4 engine
by Toyota to gain HP and relyability. On the outset they both seem to be
close in specs?? 3.0 liter 24 valve head both turbo (although the Mk4 is
twin turbo that should only improve throttle response maybe no). Is the
head that much better? There are Mk4s with 1000+ Hp w/o self destructing.
The Mk3 seems to max out around 700 HP or so. Give me some tech stuff
here if you would I am curious. Thanks in advance.
PS I love my 87 Turbo targa anyway
Head design
Mk4 Valves have wider spacing/better angle so you can fit bigger valves in.
And being a square layout 86x86 they have a lower piston speed and more room for valves.(7M is 83x91)
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
BTW: Wayne, I love your 87 targa too... :D:D:D
Welcome to the best MKIII site around... You'll learn alot! Just read, ask questions... Anything you wanna know, someone will tell you...
CTsupra
while were on this subject.
somebody please explain to me how the 2jz-gte is 86x86 3.0ltre and the 7m-gte is 83x91 3.0ltre, yet if you were to destroke the 7m-gte to 83x83 you would lose a crap load of displacement. is there a way to destroke the 7m-gte and keep the 3.0 litres of displacement without designing a new block?
reason why i ask, is i want to build a destroked 7m-gte in the near future. probably somwhere around 2.7 litres with a 8k red-line.
CT: It would be risky trying to punch a 7m out to 86 as these engines are thin wall castings and with the bore spacing so close together there's not a lot of meat there.
One of the guys had one sonic tested awhile back and I think "safe" was 85mm.
The only real "benefit" from destroking is RPM potential and as not many people want to drop the $$$ for a really good valve train this potential would be wasted.
I sat and had a think about it and used to run my old BBChev into the mid 7000's with a longer stroke with a monster Piston compared to our little featherweight ones so I can't see any problem running 8000 on a built 7m with good valvetrain.
Hope this helps.
CTsupra
Thanks IJ, you rock!
If my memory serves me correctly, I believe Mello built a 7m motor that was either .60 or .80 over, and said there was enough wall left for it not to be a problem. Since sf is down, I can't go search for the thread. Maybe he'll chime in here.
I plan on building a insane 7m in the future with a BIG ass, like Ron - jt2ma71 big, turbo, so it must be able to rev to 8k, and i'm going to go all out on the head, get custom cams made, de-stroke, et cetera.
I hear people are worrying about piston travel at such high rpms i.e over 7k with the 7m. I don't know much about piston travel and all, but I'm assuming the piston might hit the valves or something? :dunno:
What is sonic testing, btw?
Anybody else have any input?
Furball
Yes, I play Halo
Apr 2, 2005
183
Merced, CA
I believe that Defiant7M treated his block with Hard Blok and after sonic testing determined that he could go to 86mm, though he chose 85mm because the extra mm wouldn't make that much of a difference and because they were having trouble finding the right size rings.
SuprAng
Garage Queen VV
Apr 4, 2005
112
Toronto, ON
i rev to 7k + regularly. Anyone who says a 7m cant rev, only relays false information, get the power up there and she will take it. i have logs of 7300. totally stock. While the stroke is longer on the 7m, piston velocities are relatively close to the 2jz. No one has gone past rev limit long enough to find out though.
STock for stock, the main difference is that 2jz turbos flow more cfm at 10 (or whatever they run stock) psi than one ct26 at 6psi.
figgie
Twin Cities, Minnesot-ah
agreed!!
I know Melloyello was reving his to 8k rpm all the time bvefore he sold it off.
I even looked at what BMW was doing int there S54 engine.
same stroke as the STOCK 7m and they have a factory redline of 8000 rpm. Mind you that they have a bigger piston as the bore is bigger and have no problems doing that. If they can do it why the hell can't we? (not taking into consideration the stock valve train.
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
I'll be spinning my 7m to 8500 or so. Its not so much the bottom end as it is the valvetrain. They take a hell of a beating at high rpms, and with not enough spring pressure and heavy valvetrain components, floating the valves is inevitable. Kevins block was .080 over and routinely revved it to 7500. IMO destroking a 7m would not show any gains unless you plan on spinning 9000rpm+. Besides a better head and a square bore/stroke, theres nothing more special about a 2j than the 7m....
Wayne G.
87Turbo 5sp Targa
Apr 19, 2005
213
Gainesville,Ga.
Hope this helps.
Now that you mention it back in the 70s I had a 69 Camaro with a Big
block Chevy engine 4 bolt main that I built (cams valve springs balance job
everything) and it would go 7200 to 7400 rpm and remember this ingine has
4 1/4" (106mm) bore size. So maybe there is something in the MK4 valve
train that (stiffer springs lighter parts etc.) that allows more rpm. What is
the redline on a MK4 turbo? The Mk3 is 6500 rpm.
