Coolant leak by passenger foglight
csr ma71
rooftop sniper
Apr 2, 2005
254
bay area
www.angelfire.com
There's a fat puddle of coolant below my passenger's side foglight. What can be leaking around there? It's not the radiator, lower radiator hose, thermostat housing, two coolant hoses to turbo. What else am I missing? I think I felt some coolant where the cps meets the head, but I'm not sure if any coolant lines run there.
csr ma71
rooftop sniper
Apr 2, 2005
254
bay area
www.angelfire.com
Reference pic for people who search in the future for coolant leak, cps and foglight.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
1. Buy UV dye kit
2. Add dye to coolant
3. Use flashlight included with kit to find leak
4. Fix leak.
All without guessing or replacing something that doesn't need to be replaced.
honeydew
Supra Freebaser
May 10, 2007
164
Toronto, Ontario
adampecush;1706742 said:
1. Buy UV dye kit
4. Fix leak.
Probably the best mode of action, I also was going to mention thermostat housing/hardpipes dripping.
Bleakvoid
Wide-------------bodied
Oct 7, 2010
222
Fairfield, CA
1. Buy UV dye kit
4. Fix leak.
If you have a blacklight (UV light) handy, you can cut open a glowstick and dump the UV liquid in the radiator. Same thing, and most people have the stuff laying around. Just be sure to flush the coolant system afterwards with either method.
radiod
1,342
Abbotsford, BC
Try checking for wetness under and behind the thermostat housing down by the power steering pump. I had a small leak from the hose there that collected in about the same area but definitely not as much as what you're seeing.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
ahem...
1. Buy UV dye kit
4. Fix leak.
