coolant came out of the by pass valve
tyang82
487
Milwaukee
Can that be signs of a blown head gasket? I took off the accordion hose along with the by pass valve and saw some coolant dripping out of the top part of the by pass valve.
Backlash2032
1,823
Nebraska
Not sure if its possible for coolant to leak from the Turbo to accordian hose, but that sounds like what's happening to me
Sent from my ADR6425LVW using Tapatalk
tyang82
487
Milwaukee
That does sound weird but it its true. I was changing hoses and came across this problem. Now I'm starting to worry.
Backlash2032
1,823
Nebraska
Well it is a coolant cooled Turbo so I suppose a crack could form to the Turbo inlet. Theoretically.
You'd prolly lose a lot of coolant and oil if the coolant part of the turbo cracked.
I'd pressure test the cooling system and see where it leaks or if it even holds pressure.
Can also do a compression test and block test to rule out bhg.
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
IJ.;1788582 said:
My guess would be the factory BoV type thing ;)
LOL @ coolant coming out of it that's a new one :aigo:
Stick a fork in it she's "done" :runaway:
lol x2 new one for me and I thought I'd broken everything on these cars that can break.
