coolant bolt behind cylinder head
tyang82
487
Milwaukee
I want to buy it, but I can't find videos of how its used. I've never seen this type of tool before and I want to learn. Little help guys
You tap it into the hole lightly and turn with a wrench ;)
The advantage it has over a Helical extractor like an "easy-out" is it doesn't expand the broken part and wedge it tighter into the hole destroying the threads when you eventually get it out.
I bought that tool to do the exact job you're doing.
Soak it with PB Blaster for a day or so as well, when you install the new one use some Nickle Antiseize on it's threads.
It's caused by "Galvanic Corrosion" your fitting and the head form a battery when "wet" and bond to each other.
