complete engine gasket set recommendation
BrandonW
1,300
N.J.
im looking for a complete engine gasket set is their any you guys would recommend?
i know it doesn't come with a few gaskets and i will not be using the hg it comes with i'll be getting a metal hg nor will i need the turbo elbo gasket (i have a ddp)
and can someone tell me what gaskets it will not come with or will some manufacturers vary?
TooRandom
80
Seattle, WA
Well i'd it a hks? metal head gasket than just go to toyota and ask for the gasket kit. Last time i checked the kit was about 350 and came with most if not all of the gaskets
I don't remember not having any gaskets when I ordered the stock gasket set from Toyota. Call Jeff @ 1-800-327-2087
TheNewRed
572
WA
Well, most if not all the members on here will tell you not to, but i want the "cheap" way and bought a erastic kit off of ebay...its really not a bad kit at all, and comes with pretty much everything.
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
Felpro engine gasket kit.
Comes with all gaskets needed for a rebuild plus extras.
I used this kit when doing my headgasket job.
snake eyes
77
katy, tx
I got mine from a guy that was selling them here as a deal about a year ago.
Big things to remember (for mine anyway): Check EGR gasket fitment, turbo to elbow, and header to turbo gaskets, fuel rail spacer gasket things, oh and as long as your taking it all apart do all the coolant hoses (there are about 5 iirc right for main ones)
<l><l>
"Gasket" far right of the pic.
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
Toyota kit is worth every penny. :D
Only the big ballers rock it. ;)
But stone kit is pretty nice too. :)
Edit: Stone kit doesn't have the "shoe" gasket. :(
BrandonW
1,300
N.J.
Rennat;1110664 said:
http://www.store.partsdinosaur.com/product1302.html
it has ALL of the injector insulators, o-rings and seals... which amazed me. i have NO leaks anywhere on my engine from using that kit. i just threw away the head gasket though... lol
oh hmm good price too (i know you had a good experience) but sounds a little to good to be true
thats the one you ordered any problem with it saying: 7MGE 24V DOHC 3.0 Cressida, Supra
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
they send you a non-turbo and a turbo kit all in one... i had quite a few left over gaskets, i even had TWO for the y-pipe on the non-turbo... its prbably cheaper just to package them as one...
and no problems at all, the guy who runs parts dinosaur is a really nice guy and i've never had a problem. even when he confused some rod bearings for my friend! lol
it has the u-shaped gasket for the rear main seal too! and my valve cover gaskets dont leak one drop, but i also used flange head bolts. so the quality is there.
they give you exhaust elbow to downpipe gasket, CSI... ISC... throttle body i had to cut bigger, but thats common with a lot of kids, the turbo gaskets i got were MLS, the exhaust manifold gasket i got was really nice and sealed 100&#37;. they even give you the o-ring for the filter head to block!
snake eyes
77
katy, tx
thanks, I will have to check tomorrow (working at toyota and having a master tech helping me get this thing running) otherwise just another thing to order lol
edit: found out got the ITM kit with mine, EGR didn't line up right thou
Zumtizzle
Oct 21, 2006
2,825
Sac-Town, NorCal
If you use the Rennat kit.
Give the exhaust manifold gasket a spray of copper. :)
The factory gasket is graphite coated and this one isn't.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
and neither is the cometic gasket kit... and i didnt use the copper spray, only because you want it seal around the exhaust port, so i used the ultra high temp copper rtv and it worked awesome.
i prefer the copper spray for the larger gaskets like the timing cover and intake manifold where you want the entire gasket to seal up. and the exhaust manifold gasket goes ONE way, pay attention to the TSRM, the little 'hump' goes to the back...
