problem is just what title says, My car has no cold start, if the temp outside is less then 80+ it takes the will of god for the car to start, then once you finely get it to crank... it will die immediately (I mean INSTANTLY) repeat this about 4~5 times and the car may stay running long enough for you to "pump" the gas and to have the RPM's spike every time your foot comes off the peddle, then you hold it above 1500RPM for anywhere from 15 seconds to one and a half minutes and the car will FINELY idle, BUT! idle will be very high... around 1300~1500 and you may feel a slight "miss" from time to time.
The car also runs VERY rich, my buddy doesn't like to ride behind me because he has to put his top up and close all his windows to breath >.>... I also think i have a boost leak that sounds like it's on the INTAKE side of the motor, witch doesn't make sense to me because to my knowledge all the piping that holds boost is on the exhaust side right? (as the intercooler only runs to one side on the 7m right?)
Sorry guys, I know this sounds like "AFM" "TPS" "timing" blah blah blah... but i just finished putting the whole engine back together, I guess what im asking is does anyone have any ideas that might save me the time of ripping everything apart again... I just got the car running after 8 months of sitting and I'm kinda weary that if i pull it apart to start hunting down 5 or 6 issues it's going to sit for another 8 months :cry:
