Code 14
mk3supra
231
Decatur, IL
www.supramania.com
My car wont start, I pulled the codes and I have a code 14. Tried clearing it but it came back when I try to start it. Iv tried searching for info about code 14 but couldn't find much. Anyone know what could be causing this or how to get rid of it?
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
same happened to me, car was idling just fine and then just shut off without warning or fanfare...
it turned right back on, but I'm always ultra-paranoid about it now, since a bit earlier it wouldn't stay on at all, just crank, turn on and die...
hope it's not the ECU...
8,900
jetjock;1571391 said:
Yes. Read post # 2 again.
And although by now you know it isn't the EFI fuse it was never possible for it to be the cause because if the fuse was bad you wouldn't be able to read codes...
thevork;1570596 said:
14 Ignition Signal
Diagnosis
* No "IGF" signal to ECU "A" times in succession.
A = 6-8 (7M-GE)
A= 3 (7M-GTE)
Trouble Area
* Igniter and ignition coil circuit
* ECU
http://www.cygnusx1.net/Supra/TechTips/engine_error_codes.aspx
Did he say whether or not he had spark at cylinder 1?
gaboonviper85
3,236
Northeast Philly
No way in hell the ecu is fried!
---------- Post added at 06:45 PM ---------- Previous post was at 06:44 PM ----------
Btw...I'm currently dealing with the exact same problem!
