I have read a number of posts here and on SF about this issue but still have a couple of questions.
Where are the resistors located for the indicator lights? if I want to run a cc unit with white backlights for the buttons, blue indicators, blue display and red/blue backlight for the temp up and down do I will need to change the resistors on both circuit boards.
1. Does anyone have a picture of which resistors need to be changed to change the led voltage for the indicator Leds.
2. Will the legs on standard Leds be long enough to fit or do they require modification for the indicators
Any input on mcd ratings to dim/bright is appreciated
This is what I would like to end up with:
BorHor if you are still offering this service PM me and I will send you mine. Your work looks awesome and although I like to do all my own work I am a little worried about getting the temp display to look as good as the ones you have done.
