Thought this pic was very cool... the flange is made by SP and is an awesome oil line kit... Tim is still developing it, to make sure it will fit.. ALL 1jz manifolds.. SP has been a MAJOR asset in my buildup as well as 935. Although this pic only shows a oil drain flange, SP includes stainless drain line, stainless feed line, and rear feed plug... Also includes flange with AN fitting to replace the lower oil drain. And like always the quality is outstanding.
These are pics of the 1j fuel rail. In typical SP fasion, the quality is AMAZING.. The mounts use phenolic spacers which is a low heat transfer plastic. While some think this is just snake oil, SP had problems with Marco's supra, when they were using metal mounts. The fuel was boiling in the rail, when they used phenolic spacers on the fuel rail and at the injector bosses, the fuel problems stopped. Thats proof enough for me!
