Charcoal Canister?
FlikRacing
93
Michigan
I guess I looked up the subject, but really didn't find a clear answer, I do not think i really need my charcoal canister. I would like to place my oil catch can there, and then maybe that line down to the ground. What do you all think would that be fine?
HommerSimpson
1,067
New Smyrna Beach Florida
.. You will smell gas then.. i removed mine with plans on putting in the inner fenderwell on pass side.. have not got around to doing but will before back on road...
FlikRacing
93
Michigan
What if I run a tube to the back of the car lol? Or I wonder how flammable it is to run back into the intake?
Buy a small plastic JDM Cannister off one of the half cut guys and install it under the inner fender plastics out of sight.
Problem solved 100% and you're NOT fucking the car up.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
If you really want to remove it and dont want to replace it with anything, run a hose from the line down into your fender well. Theres a visible hole there somewhere with a grommet.
FlikRacing
93
Michigan
Hey, could I run the hose just to the BVSV or does it have to be " running through the charcoal canister?
Also i might want to make a new charcoal canister..
Wait...what?!?!
That will turn the catch can into a bomb...the charcoal canister has charcoal in it for a reason!
Geez...just do as IJ suggested and put a JDM canister in the fender well. This getto rigging is going to get you into a lot of trouble!
Apr 10, 2008
322
South East USA
Dude if you start bypassing that canister all your weight loss will become weight gain with the fire supression system you have to install. Even if it's one of those 90's fire extinguishers mounted in the cabin...
Crusade....thats funny
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
That thing is goudy and rediculous....
It is always pointed and asked upon when i flash my J to the peeps!!!
92nsx
2,957
Clearwater, MN
Also removed mine on my last 89 turbo ran with no problems and no explosion. I just ran the tube throu the hole under the canister(where it use to be) and installed my catch can there. Sorry this is the only photo i have my my last supra's engine bay.
And is alread removed from my current 89 turbo.
Good Luck.
