changing tire and a stud broke off!
mk3tattoos
1,104
Bremerton, Wa
i was changing the rear driver tire and was taking the lug nut off. I have them torqed down to 100 lbs, and i twisted like butter! so what do i have to do to fix this problem:1zhelp:
thanks for the help.
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
Line the back of the stud with the hole in the back of the hub and hit it out with a hammer.The dust sheld might be in the way so you have to take that out of the way.I think thats how you do it.It's been awhile am I leaving anything out?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Would be wise to change them all out as the others are probably fatigued. Its easy and cheap enough...
By the way the lug nut spec is 76 Ft Lbs not 100! That is way too high. Use some anti seize on the threads too.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
if using anti-seize, oil, or any other compound on the threads, adjust your torque accordingly to maintain the appropriate preload. (i.e. when using a lubricant, less torque is required to achieve the desired preload vs. dry threads)
Mk3runner
2,033
Nor Cal
for the many cars that I've had to hammer new studs in.. I wish I was there to catch the people that try and use a impact. torque sticks suck cuz well impact. I for whenever I need tires put on. watch the guy slamming tires and make it clear to him to by hand the lug nut to tight and torque it down. impact will be upside head if I see on used on my car.
mdr40z
arkansas
I always insisted that any shop hand torqued mine, I don't trust those torque sticks on the air guns
fool'ssupra
Building It
Sep 14, 2008
75
Maryland
I always retorque mine, regardless of the shop that does the install, and then retorque them again after several days of driving. By the way, the torque spec for the wheels is for clean dry threads.
mk3tattoos
1,104
Bremerton, Wa
so can some one tell me how to get them out, and were do i get the stud from.
i read the post were he says to hit it with a hammer. and thats it?
Dealer for perfect fit replacements, after market if you have access to power tools.
Yes they have a knurled shank that's an interference fit in the hub you just hit them using a punch and hammer and they'll pop out.
cmdeoro
VRROOOMMM!!!!!!.....PSSH!
Jan 21, 2009
103
Miami
This is absolutely true, So i would add another 10 pounds or so if you lube them up.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
you dont ADD torque if you use a "lube"... its like with arp head studs
moly lube is 75 ft. lbs
oil is 100ft lbs or something up there... its a large difference...
so if anything, i wouldnt go over 70ft lbs if you use anything on the threads.
mk3tattoos
1,104
Bremerton, Wa
I'm glad i made this thread now, i am getting great info to use. I have awlays wanted to use lube but never heard of anyone doing it thank you so much, and if there is anything else please chime in!
